Dash bulb connector troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2010, 07:53 PM
[IMG]I am having a time with several dash bulb connectors. The spring in the wire which keeps the connection with the bulb snug is forcing the metal grounding/retention clip out of the plastic end of the wire. Has anyone else had this problem or know of a solution? The bulbs are going into the speedo and tach of a 73 vette.
Thanks,
AL
Old 11-25-2010, 08:07 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
if I am looking at it right, two prongs are the ground for the bulb and the other two clip into the plastic. I would just use epoxy where the tangs push into the plastic. As long as you have a contact , electrical for the bulb and the ground on the circuit board, gluing will work
Old 11-25-2010, 08:20 PM
Yeah - you are looking at it right. I can try epoxy and see how that works.
Thanks.
Old 11-25-2010, 08:45 PM
pepi's Avatar
That would be the way I'd go at it . You might also put some epoxy on the flat area between the socket and back socket side of the contact, sandwiched.. Those lights are fairly much a standard size and a back up plan might be this, unless the bulb is the long instead of round.
http://www.speedwaymotors.com/Gauge-...-Kit,4167.html
Old 11-25-2010, 09:05 PM
Many thanks! I will try the epoxy idea first but the link is what I was looking for. Happy Thanksgiving.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 04:14 PM
justdashes/trashes my dash cozmo Interior 25 04-03-2016 08:09 PM
1964 Impala SS Dash 64Joker Interior 3 06-21-2007 11:30 AM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
