dash gauge cluster problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2013, 09:12 AM
I have a 1994 ford f150 4.9 2wd 2 door mfi automatic.
the oil gauge & temp. gauge & odometer(digital) & speedometer work fine.
The fuel gauge & voltmeter do not work.When I replace the fuel pump the gauge will work.I already replaced the fuel filter.
New battery & complete tune up.
When I put the new battery in, the voltmeter went below the #8.I had the battery checked before I bought it & after it was installed with engine running & not running.I also removed the negative cable to the battery & the engine did not shut off,so alternator is good.
What would cause this & how do I fix it?
thank you guys for any help.
Old 08-24-2013, 10:57 AM
Banned
try just turning the key on for around 10 mins. to not try to start. the computer needs to reset. just a thought. again working on any car or truck, bike. that manual is well worth the $25 .
Old 08-24-2013, 06:33 PM
ash gauge problem
I know they are handy & helpfull but,do they have the answer to my problem?
Thanks for posting your answer.
Old 08-24-2013, 06:50 PM
Banned
first off yes they help everyone that is on this forum. if you do not have the skills to work on cars, truck, or bikes, then you at the least need a manual . Really do you need your hand held. sorry Pymyno2. but if you have no clue then no one can help . need to know the basic first. no one is going to give you step by step info!!!!!!
The Following User Says Thank You to killeratrod For This Useful Post:
Pymyno2 (08-24-2013)
Old 08-24-2013, 06:57 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
If everything is working OK. I'm guessing the voltmeter is bad.
Check the actual system voltage with another voltmeter.
Did the voltmeter work OK then suddenly it didn't? Or what.
Did you replace the fuel gauge sender and now it's working? Or what.
vicrod
Old 08-24-2013, 07:02 PM
Banned
no he needs us to fix it without ever getting a little knowledge that can be used his whole life time!! no more help here!! BUY A MANUAL!!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-24-2013, 10:44 PM
vicrod
The volt meter was between #8 & the middle but,when I put ALL new fuses in,according to the amps,the needle dropped real fast below the #8.
There is a 4amp fuse I put a 5amp in.could this 1amp make a difference?
No,I have not done anything to the fuel gauge sender,yet.
Thanks for your knowledge & answer.
Old 08-25-2013, 06:34 PM
vicrod's Avatar
life is a ride
try this approach
Let's try this.
Does the car start and run OK???? YES or NO.
vicrod
Old 08-26-2013, 04:04 AM
EOD Guy's Avatar
I agree you need to give us more info on how it got to what it is now. Then maybe we can help you step by step, but we gotta start at the beginning.
Old 08-26-2013, 06:31 PM
LATECH's Avatar
Unhooking a battery cable while the engine is running is a real bad Idea.
The computer wont "Reset" by leaving the key on for ten minutes.
A scanner wont help you solve this problem.
Chances are the printed circuit on the back of your cluster has a problem, like an open circuit. That would cause one or more gauges not to register.
If you can wrap your head around that then you may be able to do something with that.
Fact is stranger than Fiction
Old 08-26-2013, 07:55 PM
[QUOTE=EOD Guy;1714474]I agree you need to give us more info on how it got to what it is now. Then maybe we can help you step by step, but we gotta start at the beginning.[/QUOTE.
OK!
Before I did anything the voltmeter was between the #8 & the quarter mark.
With the negative battery cable off,I replaced ALL fuses.The only thing I did different was,replace the 4amp fuse with a 5amp fuse.(instrument illumination).
Then connected the negative battery cable.
Then,when I turned the ignition switch to on(engine not running),the needle quickly moved to the left of number 8.
After this,I had the starter,alternator & battery checked by a certified mechanic & everything is ok.
Could that 1amp extra cause this?
Thanks for your help.
Old 08-26-2013, 08:01 PM
I didn't leave the key in the ignition.The ignition was in the OFF position.
Old 08-26-2013, 08:04 PM
[QUOTE=LATECH;1716490]Unhooking a battery cable while the engine is running is a real bad Idea.
If you can wrap your head around that then you may be able to do something with that.[/QUOTE.
Thank you for your help & answer.
Dash Cluster easygoing808 Hotrodding Basics 0 06-08-2013 06:11 PM
gauge cluster help jrbaker Electrical 1 03-20-2013 07:50 PM
90' gmc 1500 gauge cluster to 93' suburban cluster 90GMCVortec Electrical 0 02-16-2009 07:10 AM
cluster gauge trivera Electrical 4 05-21-2008 06:56 PM
What is this gauge cluster please anyone? imperial Interior 9 12-18-2005 11:33 AM
