Dash gauges and lights flickering. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 08:19 PM
Hi i have a '66 impala and the problem is very noticeable at night and very annoying. The gauges lights, signal light indicators, etc all flicker on and off constantly. Its probably just bad connections, and wanted to know what is a good solution for this. Where are the wiring connections that i should be looking to for corrosion/ bad connection, or is there a place i can buy new wiring kit for the car? Thank you.
Old 04-01-2012, 08:33 PM
It sounds like it may be the dash panel ground wire that is loose. I don't know where they connected the panel ground wire on your car, but on my truck it is connected to a bolt on the emergency brake mechanism. (Which is bolted to the body of the truck.)
Bruce
Old 04-02-2012, 03:54 AM
EOD Guy's Avatar
X2 with the loose ground wire.
Old 04-02-2012, 07:05 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
Check your alt.connection also.I had the same issue,some how some body didnt tighten up the alt.stud nut.
tail lights and dash lights quit ashman Electrical 5 08-30-2010 12:27 AM
79 TA: dash lights and tail lights fuse keeps blowing Gladis Electrical 6 12-01-2007 12:43 AM
flickering dash lights tjh211 Electrical 5 05-06-2007 05:28 PM
Replacing the lights with gauges grandprix601 Electrical 3 01-03-2004 10:30 AM
Flickering Lights horvath Electrical 7 05-19-2003 03:52 PM
