dash gauges problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2007, 12:14 AM
dash gauges problem
87 chevy s-10 2.8 v6 when i turn on my head lights all my gauges act up i don't know what to do to fix them.
Old 01-22-2007, 10:13 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
This kind of weird problem is usually a poor ground.
Check the engine-to-chassis ground strap and the engine-to-body ground strap.
A visual check is not enough. You must disassemble, clean and reconnect.
Replacing the ground straps is also a good idea.
A good reference is www.alldatadiy.com or some shop manuals will have a diagram of the grounds.
Make sure all the grounds a good.
vicrod
Old 01-22-2007, 10:16 AM
poncho62's Avatar
Wiki Edits: 5
Your dash panel also has`a ground wire on it. Chances are it has lost contact.
Old 01-22-2007, 03:14 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Also, If your Dash panel has a laminate card, The Card Plug well may be dirty, Corroded, or the plug may not be seated properly.
CAREFULLY remove the plug, and clean and burnish the pins on the plug, and VERY carefully clean the traces they plug into on the laminate card, (be very careful with these, the card is thin laminate, and by now , probably very brittle..it can break very easy.
Inspect the laminate card for any open or intermittent traces, If found, you can attempt a repair with a braided jumper (if your handy with a low wattage solder iron, and very careful not to burn the laminate) or replace the laminate card .
Be sure when installing it back, that the plug seats all the way back in (they like to pull at a 45 degree angle) and none of the laminate "finger traces" get bent when inserting the plug.
Do the grounds as I outlined in your PM to me..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 01-22-2007, 03:40 PM
Last journal entry: A few ongoing projects
As Poncho62 said the S10s have a dash ground,, as I recall it's a black wire on the back left hand side of the dash. It's pretty common for these to get loose over time and create the problems you are having.
My work in progress custom dash: advice needed. friday General Rodding Tech 6 12-31-2010 02:20 PM
Yargh, carbureator problem is driving me nuts (but not my car!) caustic meatloaf Engine 12 05-21-2006 01:41 PM
Mounting fiberglass dash mrmagoo187 Interior 24 11-04-2005 06:43 PM
'86 Camaro problem CHEVY4LYF Electrical 10 10-23-2005 08:55 PM
Dash Board Gauges 54 Chevy Interior 1 02-05-2002 08:38 PM
