dash glue removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2007, 12:29 PM
excaliberprime's Avatar
Last journal entry: back for 2014
dash glue removal
i have a dash bezel that had wood trim covering it when i pulled it off it left a glue similar to rubber cement all over the bezel. does any one have any one have any ideas how to remove the goo. iv tried goo begone but it justs gums it up. i don't want to use anything to harsh because i don't want to damage the plastic.
Old 03-15-2007, 12:39 PM
302 Z28's Avatar
About the only thing strong enough to remove the residue without harming the plastic is paint thinner (mineral spririts) not lacquer thinner. Test an out of the way area of the dash with whatever you are going to try and see if it's safe to use.
Viince
Old 03-15-2007, 02:03 PM
soak it with a paper towel with WD40....then a nylon "scruby" pad so you don't scratch the surface
Old 03-16-2007, 06:18 AM
Dusty82's Avatar
Last journal entry: The Chevy Bench Seat - Part 52
Chances are that wood trim was held on with contact cement. Check with a local shop that makes laminate (Formica) countertops, and ask them if they can recommend a contact cement solvent. Heck, if you offer to buy a cup of the solvent they use, they'll probably give it to you. (Take a jar with a screw on lid with you just in case.)
As was suggested before, try any solvent on the back of the bezel first to make sure the solvent doesn't damage it.
Old 03-18-2007, 05:47 AM
I would give denatured alcohol a try in most cases it removes adhesives with a rag and a little elbow grease with out harming plastics or rubber. But as stated before try a test panel first. I use denatured alcohol for a first pass cleaner on just about everything the stuff works well.
Old 03-18-2007, 07:33 AM
302 Z28's Avatar
Denatured alcohol can contain a host of additional chemicals like acetone and ketone to render it denatured. These added chemicals can harm plastic.
Vince
Old 03-18-2007, 08:07 PM
awert's Avatar
58/58
Use WD 40
I vote for wd40 or similar, you would be surprised what it can remove without harming the dash....
Old 03-19-2007, 05:09 AM
Wd 40
(I am a dingtbat!)
spray the paper towel with wd40 till soaking wet
lay the paper towel on the glue and let it soak 10-20 minutes
then scrub with a nylon pad
(went back and read my post...didn't make sense to me....and I wrote it!)
Old 03-19-2007, 06:35 AM
Im shocked to hear that 302 about the ketones in denatured alcohol. I was unaware of that when i was into nitro rc cars thats all we used cuz it worked so good and didnt harm any of the rubber or plastics. Unless there are different formulations? I am not quite sure what the denatured part od alcohol is all about but i thought it was similar to isopropyl alcohol just didnt flash as quick or dry out your seals and things. I guess i'll have to be more careful in using denatured alcohol for the past few years thats been my number 1 all purpose cleaner.
Old 03-19-2007, 08:11 AM
Dusty82's Avatar
In the limited internet-based research I've done, I gather that the difference between Iso-propyl alcohol and Denatured alcohol are pretty basic.
Denatured alcohol is the same ethanol found in beer, wine, and spirits, but poisonous and foul tasting additives (like acetone, methanol, and sometimes even gasoline) are put in it specifically to keep people from drinking it. According to a doctor who posted to one U.S.Government website, some of these additives can cause blindness or possibly death if you're macho enough to drink the stuff anyway. Because of these additives, denatured alcohol is not reccommended for prolonged skin exposure. Hope you were wearing gloves when you filled your RC car's fuel tank. Denatured alcohol is generally used for cleaning and sterilizing medical equipment, and not on the patient.
Ethanol makes a fabulous fuel because of its volitility. There are special camping lamps and stoves designed to burn ethanol (or denatured alcohol,) and it is also the basis for some of the alternative fuels we see being pushed for use in our cars.
Iso-propyl alcohol is synthetic alcohol that is specifically formulated to be safely used on the skin. It is not ethanol, and will not make you drunk, just sicker than a dog if you try to drink it. It's also dilluted with water to about 70% strength, which might explain why it's a rotten fuel for RC cars and such.
Sources:
http://www.newton.dep.anl.gov/askasc.../chem00102.htm
http://sci-toys.com/ingredients/alcohol.html
Old 03-19-2007, 08:26 AM
302 Z28's Avatar
The typical fuel for R/C cars and R/C aircraft is a mixture of methanol, lubricitating oil, and nitro methane. I am not aware of denatured alcohol ever being used in R/C engines. The level of nitro methane varies from none to as much as 75% to 80% for competition engines.
Vince
Old 03-19-2007, 06:44 PM
boatbob2
glue removal
Hi,go to napa,or a paint supply store and buy a qt of 3M adhesive remover,wet a paper towel and leave it on the glue for awhile. Im boatbob2
Old 03-20-2007, 07:20 AM
Your right 302 i used 20% nitromethane with oil blend. I used the alcohol for cleaning the motor and frame and all the other car stuff on them. I was told by alot of the other hobbiests that it wouldnt hurt my seals or rubber. Ive never had any problems with using it but i'll be more careful in what i use it for from now on thats for sure.
Old 03-21-2007, 06:42 AM
Wax and grease remover.
Old 03-21-2007, 07:00 AM
kruzr's Avatar
street rods forever
Just an idea..if goo softens it,try duct taping over it and glue should come off with tape....
justdashes/trashes my dash cozmo Interior 25 04-03-2016 08:09 PM
65 chevy stepside dash removal 65truck Interior 7 01-26-2008 12:32 PM
Dash Removal Chevydee Interior 2 12-20-2005 10:33 PM
64 chevy truck dash removal rivannaman Interior 4 10-03-2005 04:19 PM
Switch removal from dash oils65mustang Interior 1 08-22-2003 03:01 PM
