Dash Igntion Switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2009, 08:13 PM
chewyscool's Avatar
Big Block 454
Dash Igntion Switch
I have almost finished with my rewire using an EZ Wiring kit. The kit came with colum Ignition Harness plugs. My car has a Dash Ignition and I need help.
After wiring all that I could figure out to the dash switch (starter, Batt, ACC) I'm left with 2 Pink wires from the harness labled ING SWITCH and ING COIL. Both of these wires are the same size. I have 1 prong left on my dash switch that that gives 12v in the run position. The question is which wire to trminate at the prong? Or both? I have a wire for the coil in the engine bay that will be used for a MSD box. That wire goes back to the fuse panel as well as the 2 wire left over in the Colun Ing. harness
Old 02-13-2009, 09:22 PM
life is a temporary assignment
I have a new ez_wiring kit.And it only has one pink wire that goes to the dash,IGN COIL,The one I have that say's IGN SWITCH IGN Is Brown.are you sure they are both pink,They shouldn't be.
Them two wires should hook up to the prong that says IGN..Which would be hot on run. Where are you in LA ?
Old 02-13-2009, 09:40 PM
chewyscool's Avatar
Big Block 454
I,m in Lafayette, Yes the two wires are PINK, so you think I should double them up on the prong? I also have an Ignition relay that is not used in the oringinal wiring. What do you think about that?
Old 02-13-2009, 09:45 PM
Is this on a Chevy motor? If so..I never use a Ignition relay on any of my Chevy's,And never had a problem yet.Just make sure you have a good IGN switch.(Not a cheap one)..I would think you can hook them together.But I have never seen two the same color.
Old 02-13-2009, 09:54 PM
chewyscool's Avatar
Big Block 454
Yes chevy motor, and it makes sense to me to terminate both pink wires as I have just seen on a HUGE!! schematic a few threads down called new wiring harness. Are you in lafayette, I'm also looking to recover my seats. Thanks for the help!!!
Old 02-13-2009, 09:56 PM
No. I'm in Lockport.55 miles North of the gulf.
Look in your ez_wiring book.Page 13. It show's the back of the IGN switch.
Old 02-13-2009, 10:03 PM
chewyscool's Avatar
Big Block 454
Alright, I've been there a few times, my neighbor is from there, a Gauston or Mella her ex-married name.
Old 02-13-2009, 10:07 PM
Don't think I know her.
Old 02-13-2009, 10:22 PM
This may help.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 05:14 PM
Wiring a switch panel tommer2 Electrical 3 10-19-2008 02:28 PM
1964 Impala SS Dash 64Joker Interior 3 06-21-2007 12:30 PM
GM switch info(application) sha_ba_do_bang Electrical 5 10-23-2006 12:01 AM
Switch panel for 32 ford dash ford427deuce Interior 2 12-24-2004 06:29 PM
