Dash layout - please vote! - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: Which dash layout? '66 GTO Vert custom
Put 2 gauges BELOW the dash and keep the radio 4 40.00%
Put 2 gauges where the radio goes and use Secret Audio 6 60.00%
Voters: 10. You may not vote on this poll
Old 02-08-2009, 10:01 AM
I'm working on making a custom dash using autometer gauges for my '66 GTO Vert restomod. I'm using 8 gauges (speedo, tach, volt, h20 temp, fuel level, oil pressure, oil temp and fuel pressure). I have .063" engine turned aluminum I'm making the face from, and will use "factory type" chrome knobs and chrome heater/fan controls. I was going to use a Custom Autosound USA630 vintage type radio in the normal radio mounting location, and then mount the remaining two gauges below the dash. However, I can also use that opening to mount the remaining two gauges and then use a Secret Audio SS (w/RF remote) for the radio.
Here are a couple images. One is with the exact layout retaining the radio, though the radio measurements will be different because of the radio size. The backing material will be different of course.
Please let me know your opinions. I'm kind of leaning toward getting all the gauges in the dash right now.
Old 02-08-2009, 11:07 AM
I like the looks of the bottom one the top one looks like there out of place I think
Old 02-08-2009, 11:11 AM
Also, just to be clear -
If the radio stays in the dash, there will need to be two gauges mounted BELOW the dash separately. So you need to also picture a pod/panel with 2 gauges below the radio in the 2nd picture. There will not be a console in this car.
Old 02-08-2009, 09:32 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
i would move the radio, put the heater and air controls where the radio was
mount the two gages where the heater and air controls lived
makes scanning the instruments left to right
keeps the hand controls, knobs and levers all in a line across the bottom, clean
Old 02-08-2009, 10:02 PM
life is a temporary assignment
I like the look of the bottom picture....
Old 02-08-2009, 10:25 PM
I truly appreciate the intent, but that's not in the cards. The two choices are what I have. In the '66 Pontiac A-Body, the actual steel dash is behind the plastic bezel. The bezel has a pre-formed area that is reinforced to handle the weight and stress of the heater/fan controls. The plastic bezel perimeter is also completely exposed, requiring that it be used. Moving the heater/fan controls down is simply not possible without completely discarding the entire plastic bezel and gutting the steel behind it.
Old 02-08-2009, 10:27 PM
I'd like to make sure that people who like the bottom pic recognize that it won't look exactly like the bottom pic. As mentioned, I'll need to add two more gauges and I'm not going to have a console. If everyone realizes this no problem. Just want to make sure that people arent' just glancing at the pics and not understanding the question.
Old 02-09-2009, 07:43 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I would not hang any more gauges below the dash.
Old 02-09-2009, 05:25 PM
I realize the second photo isn't of the car in question - but are you planning on installing a center console like in the 2nd picture? If you are, I'd consider relocating the radio to the console instead of having it hidden if the car is going to be seeing some miles.
I'm not a fan of hanging gauges below the dash - but if it came down to it I'd make a fiberglass form below the center of the dash using the contours of the original for cues and match the turned center section to make it look like its supposed to be there.
Old 02-09-2009, 08:06 PM
I am not going to use a console. I want to keep the interior a bit more "clean".
Old 02-09-2009, 09:23 PM
Heres a few that lets you keep your radio and have all your gages.
Shane
Name:	Copy of 8February2009001.jpg
Old 02-09-2009, 11:05 PM
I really appreciate the ideas, folks, but...
There is a reason I had the two choices. The design and construction of the original dash (which must be used) is such that there is only so much room. I realize it's easy to move around circles on the picture, but the problem is that I need to retain some amount of the plastic bezel. In the above post, the 2nd and 3rd pic are just plain not possible without risking serious stress issues. It would require removing so much of the bezel that there wouldn't be enough left and the bezel would be far too weak - plus the switches would no longer have sufficient plastic to mount. I also need to leave some amount of plastic inside the bezel all the way around so that the metal panel has something to seat against. There are only small and weak mounts on the dash which I've highlighted with yellow arrows. Note how I've already had to cut out plastic. It "may" be possible for the top one to work but it would be very close. Keep in mind that while you can purchase a new 67 bezel, the 66 is different and is not remanufactured. I need to be careful with this. And it has to live comfortably in a 600hp based vehicle.
Old 02-10-2009, 08:11 AM
wmhjr you got to do what you got to do. It will look alright the way you have it its your car RIGHT, go for it
Old 02-10-2009, 04:33 PM
Hmm I didnt realize it was made like that. Is the plastic just a flat piece or is it molded around the sides Cant really tell from the pic.
Shane
Old 02-10-2009, 04:48 PM
It's not flat. The sides stick out and then curve around.
70-72 Chevelle Chevelle dash wiring Problem skeeveman Electrical 19 10-13-2016 05:14 PM
justdashes/trashes my dash cozmo Interior 25 04-03-2016 09:09 PM
My work in progress custom dash: advice needed. friday General Rodding Tech 6 12-31-2010 02:20 PM
1964 Impala SS Dash 64Joker Interior 3 06-21-2007 12:30 PM
Custom Dash Layout for 48 hot rod.. PRO 48 fleetline Interior 19 01-20-2007 12:59 PM
