dash lights and turn signals - again - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2003, 02:07 PM
SteveMach1's Avatar
New Member
Ok I entered this in before - but I have some more information - I have put in new Alternator - the voltage regulator checks out on the bench - Problem is that at night when I first start up and turn the lights on the dash lights and turn signals work ok (a little weak but ok) but about five minutes of driving I can barely see the dash the turn signals don't work hardly - I bought a new battery today - haven't put it in yet - but does anyone have any ideas. The head lights never dim.
1973 Mach 1
steve
Old 12-12-2003, 03:20 PM
EBlack36's Avatar
Rebuilt Excitment
It could be the headlight switch. Could be dirty contacts inside. Best way that I found to check out is with an olm meter.
Old 12-13-2003, 11:22 PM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
Sounds heat related, perhaps the main feed coming into the dash area is loose or the crimps are corroded. Because it's signals and lights it would seem maybe even a problem at the fuse block. I just tore the whole dash out of my Jag and went through all the connections and replaced anything that even had a hint of not looking right. Then I wire tied all the wires up into nice harnesses. NOW all my gauge lights work and several other problems went away.
First rule of thumb I have is if the P.O. did something to the electrical redo it.
Regards
Mark
