dash paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2009, 08:38 AM
dash paint
I have an old chevy blazer that I am restoring. I need to find out what type of paint to use on the dash and plastic door panels. It is going to be just an off roader for desert use so I cant justify spending money on new plastic but at the same time blue dash, brown kickpanels and grey door panels are a little much.
Old 10-02-2009, 08:57 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you use an adhesion promotor you can then just use the same BC/CC you would use on the plastic bumpers we have on new cars..
Sam
Old 10-02-2009, 09:23 AM
Trique Manufacturing
Is the dash vinyl or plastic?
Dupli-color makes some really neat paints for vinyl and plastic. Like stated above though, if it is for plastic a good adhesion promoter and paint is the best option. Be careful with some of those adhesion promoters though. If you get a little carried away with them, (some are clear and it is easy to do) they will wreak havoc on your finish.
If it is on vinyl though I would lean more towards the Dupli-Color stuff.
Regardless of what you use though make sure to use a wax and grease remover and clean the places to be painted very well before doing anything. Plastics soak up products like Armor-All and other interior cleaners used over the years and will cause horrible fish-eyes in your paint job.
Old 10-03-2009, 02:08 PM
DanTwoLakes's Avatar
Wiki Edits: 22
SEM products are great for plastic, leather, or vinyl. Here's a link: CLICK HERE
Old 10-03-2009, 05:04 PM
If you're willing to settle for a rattle can job, check out Krylon Fusion paint. It's made for use over plastic, and it works pretty well. Get one of those handle attachments for a rattle can that provides a handle and trigger, and you should be able to do a decent paint job. Obviously not as good as a good spray gun could do, but if you're looking for cheap, it's an option.
Old 10-03-2009, 11:29 PM
Wiki Edits: 22
Don't try to use Krylon Fusion on vinyl, it won't work. Plastics only, and then be careful which plastic you put it on.
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 12:09 PM
Marine enamel paint over tremclad flat black. need some advice. ElCa/monty Body - Exterior 3 08-30-2007 04:37 PM
Sherman Williams Clear Coat Failing < 3 Years? DeJarnett Body - Exterior 33 12-11-2005 10:39 AM
Basic of Basics - Choosing a color Centerline Body - Exterior 1 11-26-2005 09:12 PM
