dash probs! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2004, 12:17 AM
68firebirdguy's Avatar
dash probs!
I have a 68 firebird and tonight all of the sudden out of nowhere my dash is not lighting up. My spedo and gas gauge are not lighting up in the dash as well as my water temp and oil pressure gauges which are in the center console. Anyone have an idea of why this suddenly happened? My headlights, turn signal and warning lights all work, etc.
Old 03-24-2004, 06:30 AM
poncho62's Avatar
Wiki Edits: 5
Check your taillights. If they are not working, you have blown a fuse.
Otherwise, it's probably a ground problem in the dash.
I would bet on the fuse.
Old 03-24-2004, 08:24 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Also check the headlight switch.
Old 03-24-2004, 08:57 PM
jmhollis's Avatar
79 El Camino
Last journal entry: Trans attached
I know this sounds simple, but if the brake lights work then check the dimmer setting...
