Dash repair. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2005, 08:35 PM
Dash repair.
If any of you followed one of my previous threads, i have just purchased a 70 SS chevelle dash. *Pics here*
It has a few imperfections that i want to correct mainly holes and scuffs.
I bought some Permatex 5 min plastic weld for a couple bux and was wondering if i can use that to fill the holes with.
I need something that is sandable and permanent.
Or should i just go with Eastwoods Kit
Also before i paint i obviously need to clean it up.
What should i use for that?
Old 08-31-2005, 02:03 PM
willys36@aol.com's Avatar
Wiki Edits: 21
That is hard plastic so any resin based patching material should work. 5-minute JB weld comes to mind as a product that should result in a patch with properties similar to the base plastic. They are small enough that I would fill the holes then sand and carve the pattern in. Wipe it sown w/ lacquer cleaner and spray it with a coat of epoxy primer. Precision sand the patches and any other blemishes that show up under the primer coat to perfection then spray with the final color.
Old 09-01-2005, 07:46 PM
joeford's Avatar
36 Dream
Speaking of Dashes
Anyone know of a dash that will fit a 36 ford coupe other than a 36 ford coupe. For instance will the truck dash fit? others???
justdashes/trashes my dash cozmo Interior 25 04-03-2016 08:09 PM
Dash pad repair Steves66 Interior 2 08-01-2005 12:19 PM
Repair of dash? Paint or something else esears Interior 11 09-25-2003 11:57 AM
Dash repair for El Camino piperman Interior 3 07-01-2003 09:35 PM
Dash repair John Boy Interior 2 02-11-2003 08:42 PM
