Date Codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2009, 01:16 PM
Date Codes
What type of parts are date coded and how can I find out if a particular part had a date code?
I'm asking because I have a numbers matching 1979 Camaro Z/28 with a build sheet. The cam, intake, carb, and air cleaner have been upgraded at some point in its life. I want to go back to the originals, but I want the date codes to be correct. From what I have seen, the air cleaner and intake are date coded. Would the cam and carb be date coded as well?
Old 03-24-2009, 10:37 AM
I can't really help you with the intake, cam and air cleaner (other than to say locate whatever style would have come on your car stock - don't know if the intake and air cleaner are date-coded, and the cam wouldn't matter too much I'd think - especially since you can't see it), but the carb would have a stamped code identifying it's application - you would have to match up this stamp in order to have a numbers-matching carb.
Carb decoding info
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
350 Chevy block casting question flyin99 Engine 7 08-14-2006 08:55 PM
96 Silverado Pickup Diagnostic Codes Dave Danger Engine 14 07-06-2005 08:57 PM
I got a date I GOT A DATE! 87442lover Hotrodders' Lounge 14 04-18-2004 08:58 AM
Can't Find Casting Date on 12-bolt PrimaDude Transmission - Rearend 0 03-11-2003 07:25 PM
