Datsun electrical problem (daughter's car) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2011, 06:13 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
Guys I need some help. I was able to get this 280zx running back in the fall. Now I have completed the body restoration minus paint and I want to get the interior installed. However, when I crank it it blows one of the ignition fuses. I traced the problem to a short to ground on a +12wire. So I started removing wires from this circuit. Datsun ran a hot wire off the ignition switch then split it 4 ways with splices. I cut one of the wires and the short to ground was gone. So I checked the wire I cut away and it was NOT shorted. I played this game for a while with no luck. It doesn't make sense that a combination of wires would cause a short to ground but no single wire shorts to ground alone.
Frustrated!
need help electrical problem lets_baja Engine 1 02-22-2008 03:45 PM
electrical problem dragonboy Electrical 1 01-22-2007 02:37 PM
Electrical problem on my 55 Bel Air Jim Standley Electrical 11 07-15-2005 09:32 PM
hey everyone! electrical problem! Help please! 74duster Electrical 6 04-29-2004 11:58 PM
electrical problem pintoperformance Electrical 2 12-12-2003 09:28 AM
