David Vizard - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2009, 09:18 PM
900hp 350?
As we all know David Vizard is a respected engine builder that has written many books and articles on the subject so normally i would question what he writes but the other day I picked up one of his books and was truly baffled.
He was talking about combinations that he had supposidly built and tested. This engine was a 350 that he said he build for under 10,000 dollars and managed with the aid of nitrous to make 900 HP.
My comments on this is:
First using a stock 4 bolt main 350 for 900 HP levels is not wise and is pushing it just too far - the same goes for the stock crank, cast iron or not
Also a number of the parts were claimed to have been from swap meets but he didn't break down the price of the parts. I also don't have much faith in people's claimed swap meet prices.
Anyway the parts listed for the build are as following:
1.) Block-four bold 010 truck block bored .030
2.) Pistons-Forged Ross flat tops
3.) Head gasket-Felpro
4.) Final CR-10:1
5.) Crank-Low mileage factory forged and ground -0.020.
6.) Rods-used Crower 5.7s from swap meet
7.) Oil Pump-stock reworked; MM&S
8.) Pan-Moroso
9.) Cam-Crane dual pattern Part No. 113801
10.) Lifters-Crane regular
11.) Valve Train-Isky aluminum. 1.6 intake, 1.5 exhaust; Isky pushrods; MM&S timing set
12.) Heads-041s ported for N2O use; bronze guides; screw in studs and flat milled
13.) Intake-Victor Jr. with plate nitrous kit mounted on it
14.) Carb-reworked 750 Holley to 820cfm
15.) Air Filter-K&N
16.) Ignition-HEI with MSD module; 20* total with nitrous, 32* without nitrous
17.) Plugs/Cables: MSD
18.) Headers-Walker 1 3/4 inch with 18 inch collector extensions
19.) Mufflers-Open exhaust
So what do you all think?
Old 09-25-2009, 11:08 PM
Thats why they say "The pen is mightier than the sword"!
Old 09-26-2009, 02:26 AM
David Vizzard
HP does not break and engine at nearly the rate that rpm does,if it was done at 6000 rpm with 500 shot it is very possible although after 2 or 3 runs I would duck from flying rods,.
In his book how to build a sbc on a budget I built his # 3 combo and have it in the same car as his test car a Z28 I ran a 13.68 at mph it cost me 2,500.0 Canadian dollars to build. He does not BS.
PS my brother in his 90 mustang gt convertible with a stock motor with 22,000miles on it put a 400 hp Nos kit ito it total hp 625 on paper 17 runs and all he blew were the head gaskets,never say never he ran 11.79 with drag radials and flowmasters,on run # 24 the motor grenaded.
Old 09-26-2009, 03:17 AM
techinspector1's Avatar
Wiki Edits: 326
So the motor lasted for 5 3/4 miles.
Old 09-26-2009, 07:24 AM
david vizard
YUP , I won't deny he wasn't asking for it
Old 09-26-2009, 08:25 AM
Banned
A lot of it depends on exhaust flow and the nitrous shot. If he had a 400 shot on it it would be feasable, BUT the block will not last too long. A 500hp sbc isn't anything too uncommon, put a really good flowing exhaust with a 400 shot on it and the power can be made. Holding it all together is another issue.
Old 09-27-2009, 06:53 PM
Interesting. Thanks for the input fellows
Old 11-03-2012, 09:19 AM
Banned User
No, i agree; i don't see how a stock block could last more than 40-50 runs regardless of what rpm it is run at. And i think in this case it would have to be at least 5000rpm.
Old 11-03-2012, 09:56 AM
wwilliams181's Avatar
I didnt know he was an "Engine builder".. Worked with him a few times when i was at Comp Cams and never cam across as one. He did an Article i help him with on Valvertain Combiations for 302-351 fords.. mostly springs.. behive, ovate wire and standard double springs. I had to help him with way more than i should have if he was and engine builder.. i thought he just did tech articles to help people. With that being said.. I think the article should read under $5000
Old 11-03-2012, 11:03 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
I think he teaches at a Ohio tech school where he is tenured.I think is costs about $2,700 to attend one of his seminars.
Old 11-03-2012, 11:05 AM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
Originally Posted by hcompton View Post
Why do you think its BS. People do it all the time in drag cars. Engines never live all too long but i bet it would go two full race seasons without a hicup.
We see this every weekend at the track. You have the guys that spend thousands every week and the guys that run really fast cars for next to nothing. N2o is hard on pistons and big power is hard on rods and crank but it seemed like he covered all the bases forged crank good rods why would it come apart. The stock crap will take 500 hp.
I have a friend runs an old tubbed chevy II with 307's always builds his own motor in his garage and only uses free parts cause his wife wont let him spend a damn penny on his car. He runs super big cams and spins the engines as fast as he can. He just got a set of 2.02 heads. His 1.95 took him into the low 10's Its his personal lifes goal to run 8's with a 307. Sound silly, hes not that far away...
No reason to think a good builder cant put a 350 in the 900 range with cheaper and used parts. Now if he said he could do it in a N/A setup for cheap then i would be suprised. But with a shot of juice sure it will do it.
loving this thread
Old 11-03-2012, 11:58 AM
Banned User
I'm not saying the reciprocating assembly couldn't handle it if it was forged etc. What i'm concerned about is the stock block itself; i'm skeptical how long it would last at 900hp.
Old 11-03-2012, 01:08 PM
Banned
Well putting 900 to the ground for many miles would probably trash it. But with a shot that big you probably cant hit it right away so its going to make power mid track and beyond and hook up maybe even less. So its not going to be hard on the motor all the time. Most of the time he has a 400+ hp mouse and a big secret. It might run forever on the street how many times you going to push the button on the highway or hit a 500 shot coming out the walmart parking lot.
Ive seen many turbo cars run big numbers but they sometimes pop the first time you get some slicks and stick at the track. On the street they could spin street tires over all day long and not hurt the engine.
Yes blocks will come apart at the 1000 hp range but not all of the fixes are costly some are pretty cheap and could be in budget. Good cheap machine work is not easy to come by so maybe bull on that count.
no one ever said the 900hp engine lasted more than a dyno run. In actual use a stock block can't take extended use of more than 400-500hp without having a serious risk of failure.
Old 11-03-2012, 05:30 PM
I think you have to keep it in perspective, he made 800+ hp with swap meet/junkyard parts. I think the idea was to demonstrate the possibilities. I don't think anyone would build this motor with new parts and a stock block. I really can't imagine anyone building this much motor and only spinning it 6500 rpm. I'm looking at the version on page 156 of How To Build Max Performance Chevy Smallblocks On A Budget, I think it's the most recent printing, it's a 93 4 bolt block not an 010, it's got an AED carb that flows 945 cfm and ported bow-toe heads also a forged crank not cast and a Comp cam.
Old 11-04-2012, 05:33 AM
1Gary's Avatar
Yrs ago a certain someone won a Can-Am national with a auction circle track roller cam that everyone said wouldn't work.1.27 60' times and it is all about the combo.
Hot Rod church for sinners Nightfire Off-Topic 53 11-11-2010 08:50 PM
David Vizard book article henny496 Engine 12 01-12-2009 03:27 PM
David Vizard says "No" to PowerTV Jon Hotrodders' Lounge 3 05-05-2008 09:38 PM
How great is David Vizard's book on SBC heads, anyway? BinderDriver Engine 12 04-22-2008 05:55 PM
David Vizard rusty9663 Engine 2 10-31-2002 01:57 AM
