day time running lights - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2004, 07:41 PM
Trav's Avatar
Luv the smell of burnt RICE
i just baught myself a 1997 ford F250 heavy duty.. its got very dull running lights.. i'd like to disconnect them.. if there is such a way? any help is apprecaited
Old 02-01-2004, 08:01 PM
New Member
see if u can pull a fuse to em. that's the quick way.
Old 02-01-2004, 11:27 PM
Trav's Avatar
thats wut i was thinkin of doing.. just a matter of finding that fuse..
Old 02-02-2004, 08:07 PM
Trav's Avatar
well i found the fuse for it.. but it also knocks out the horn, high beam flicker.. and reverse lights.. hmm i dont' want that tho.. theres gota be just a wire i can cut.. wut are those 2 relays beside the master fuse panel under the hood? theres relay 1 and 2... theres a relay in the #1 slot.. but not 2.. maybe this has anything to do with the lights? i don't no..
Old 02-02-2004, 10:28 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Hey, Trav
The relay is probably for your headlights.
Why not just remove the light bulbs?
Alan
54 Chevy Pickup
Old 02-03-2004, 06:08 AM
Trav's Avatar
the reason for not removing the light bulds is because there is only one buld in there.. day time lights are the high beams on a dim setting.. theres gota be a module for the whole day time light set up.. just a matter of finding it to unplug it..
Old 02-03-2004, 09:14 AM
xtreme off-road's Avatar
There should be a box with a big heat sink on it. Usually mounted to the firewall, beside the rad or even behind the bumper.
Old 02-04-2004, 08:05 AM
Steve karch's Avatar
Don't forget that the cops can and will pull you over if your drl is not working. Its not worth the ticket.
Old 02-04-2004, 09:36 AM
docs57's Avatar
Why unhook them , they are a great safty feature, probably have saved a lot of people from accident's, jmo. Doc.
Old 02-04-2004, 07:01 PM
Trav's Avatar
well i run the marker lights instead.. that way the tail lights are on also.. and i can have those running lights out when im leaving my house at 4 am and shiining in the windows of neighbors houses. .. thanx for the replys
Old 02-05-2004, 10:22 PM
Trav's Avatar
xtreme off-road - thanx man.. u were right.. behind the bumper.
Old 02-06-2004, 05:57 PM
Your welcome. What a wonderful place for the module. When you get into $50 dollar bumper bender, you have to replace a $200 module.
