Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dbc
Thread: dbc
Old 05-22-2011, 06:09 PM
mr4speed mr4speed is offline
DBC has a 24 hour recoat window, which after that time must be sanded and re-based. It has a mask off time of about an hour to be on the safe side. You really should not have to re spray your base after 2-3 coats anyway unless you have a ton of trash in it. Be careful what grit paper you are going to use, with the base mettallics they are not too forgiving with covering up a course grit scratch as a solid color will. I usually use 1500 grit with wax & grease remover as a lubricant to "wet sand" just the trash areas only.
