dbc 2000 colorsand - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2012, 09:21 PM
dbc 2000 colorsand
I just sprayed a tank with dbc 2000 and I noticed this imperfection. I am not sure if I missed this sanding or something got dragged through it. I decided before I clear it to colorsand it and then put one more coat of base on it. Should I use about 800 grit and completely remove this? I am a little nervous about going all the way down to the primer and making the problem worse. I guess the question I am asking is wht is the correct way to colorsand before reapplying base then clear thanx......Steve
Old 02-16-2012, 06:09 AM
da34guy's Avatar
Hit it with 800, dust more color over that area and hit it with clear
Old 02-16-2012, 08:34 AM
wet or dry?
Old 02-17-2012, 06:14 AM
deadbodyman's Avatar
Wiki Edits: 11
ether one but sand and clearthe whole tank not just the spot
Old 02-19-2012, 10:51 PM
Last journal entry: My junk
Get the base perfect before you clear or it's there forever!
Old 02-20-2012, 01:01 AM
color sand..
umm..as a professional bodyman and refinisher.. the way i would do it is.. sand the entire surface with 800-1000 grit wet or dry dont matter.. then wipe it clean and tack it.. spray 1 coat of blender on the surface then blend the color over the area of the imperfection. when it disappears spray with 1 control coat to orientate the metalic. then dont tack it.. spray with 2 coats of clear and viola. a perfect panel.
2000 Silverado 1vetteman1 Electrical 2 07-29-2011 03:54 AM
454 600 ftlb @ 2000 rpm? Torque454 Engine 6 02-21-2009 03:01 PM
2000 gmc 4x4 novakidd 63 Hotrodding Basics 4 01-28-2007 06:55 PM
4.3L will not run above 2000 RPM 2000blazer5speed Engine 6 06-11-2004 05:54 AM
2000!!!!!!!!!!!!!!!!!!!! stonedchihuahua Hotrodders' Lounge 7 03-25-2003 05:32 PM
