I'm trying to decide whether I should go with PPG Urethane (DCC)or Base/Clear (DBC). Since the car will be solid black I'm leaning towards DCC. I've also considered going with PPG Laquer but I think it would probably be a bad idea even though I could save a few bucks.
I don't have any bare metal so I was planning to just use K36 and then DCC and be done with it. If anyone has done this combo before I'd appreciate your opinion. |
Lite, are you using K36 as a sealer,Or as your spot primer?As you can use it as a sealer too.(just a different mix ratio for sealer)
Pros of DCC- 3-4 coats and your done(4coats if your going to cut and buff) Pros of DCC- will be a tad cheaper on pocket book. Cons- it stays wetter longer so it has more chances of more dirt to get into the paint job. Pros of DBC- will dry faster between coats, and can use 1000# sand paper to nib the dirt specs in base.((plus any runs or sags) Pros of DBC- DBC has a hardner also to dry it a tad faster. Pros of DBC- you can tac it between coats. Cons of DBC- 3-4 coats of base-then 2-3 coats of clear. (2021 clear?2042 clear?)you will just be walking around the car a few extra times with base coat /clear coat system is all. either way is a good choice. If it was me I would go DCC , and you can add 2021 clear (mixed to its proper ratio) into mixed DCC color on your last coat for a little better UV protection.(ppg reccomends this on DCC) Hope this gave a little insight SprayTech P.S. just make sure you use a charcoal resperator when spraying!!3M makes a desposable one in 3-4 sizes to make sure you get a proper fit. (I use a full face mask by 3M) |
| Matte Black on Gloss Black | blacksunshine | Body - Exterior | 15 | 11-02-2009 09:16 PM |
| verbal description of raven black as compared to black | Dubz | Body - Exterior | 5 | 02-24-2004 12:01 PM |
| Black is black? | dh79 | Body - Exterior | 5 | 02-07-2004 04:38 AM |
