Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - DCR Calculation
Thread: DCR Calculation
Old 01-16-2013, 08:37 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Here is a good article on dynamic compression ratio:
Classic Inlines - Compression Ratio's
As you can see the dynamic compression is what the engine actually sees in operation. This can be manipulated by valve event timing in other words at what point in the cycle of the cylinder does the valve actually close.
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
thinwhiteduke (01-16-2013)
