Running seat to seat duration is not the same as Advertised duration. Althou there is a SAE standard.
Nobody uses it. In a strict sense. GM once used .001" .001 .009" "lash point duration" etc. Just one of the flaws of this DCR theory stuff. |
Yep you got to measure it for most cam or call and ask what the actual measured specs are.
Is .006 or .001 best to use for dcr? When using a dail indicator right on the retainer. |
Different manufacturer's give absolute degrees in some value other that truely shut valve degrees these are often measured from .001 to .006 inch from the seat. While not "perfect" this is a lot better situation than from .015 inch or guessing that the cam actually seats the valve with an additional 15 degrees as many cams, especially older grinds have extraordinarily long ramps and 15 degrees doesn't get close to true valve closure. Bogie |
I can't figure why it was dumped either, I learn a lot by reading through these posts too.
F'BIRD-88, this is for you in regard to you question in the 'dumped' thread. I sent to you PM also, before I found this one. My aim was to achieve 11:1 SCR, or real close to it. If my heads were as advertised at 64cc , that's right about where I would be. The combustion chambers in the heads were measured accurately with the correct equipment by me and my machinist at his shop. The block, a 2 bolter from a '73 Impala, was stock everything when I tore it down. Never had the heads of, factory. Specs are now, Bore: 4.030" Stroke: 3.48" Piston to Deck Clearance: .005" Head Gasket bore: 4.060" Head Gasket Compressed Thickness: .030" Pistons: KB171-020 hypers with compression distance of 1.561", not rebuilders. Valve reliefs are marginal at 1cc, actually not even 1cc but I called it that. My machinist and I fly cut the pistons to give minimum piston to valve clearance as I was chasing compression. Head Chambers: 61cc Let's know what you get. Duke |
"Rude personal attacks are not tolerated here and I am not sorting out any ones personal complaints. I am dumping this thread so if you guys wish to discuss this topic you can do so in a polite and courteous way.." Sam .................................................. .................................................. .................................................. .................................................. ........... I personally would like to see this subject continued and I promise to be civil. I have no idea who wrote the straw that broke Sam's back and don't care. Richard Last edited by techinspector1; 01-16-2013 at 03:52 PM. |
DCR Calculation
Misprint, yeah probably, I just used the 'narrow your results' column in the search page on summits site and typed in 4.030 and that's what came up. I thought the p/n looked wrong when i typed it in. Anyway the machinist had the pistons before he bored the block so I'm sure it's ok, but I'll check my paper invoice when I get home on the weekend too be sure! Ya got me scared now! Thanks. Duke |
Here is a good article on dynamic compression ratio:
Classic Inlines - Compression Ratio's As you can see the dynamic compression is what the engine actually sees in operation. This can be manipulated by valve event timing in other words at what point in the cycle of the cylinder does the valve actually close. Sam
| The Following User Says Thank You to OneMoreTime For This Useful Post: | ||
thinwhiteduke (01-16-2013) | ||
| fully understanding DCR | prostcelica | Hotrodding Basics | 34 | 01-17-2013 11:32 AM |
| ? about DCR for my 350 sbc | streetmaster42 | Engine | 7 | 03-13-2008 01:06 AM |
| Another DCR question. | Hippie | Engine | 7 | 08-04-2005 01:00 PM |
| hp and e.t. calculation | camino_man | Hotrodding Basics | 1 | 06-21-2004 08:19 PM |
