dead battery - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2013, 08:12 AM
dead battery
I have an 84 vette. new battery, alternator, etc. not had any issues until last week. battery was completely dead. checked to see if something was one. Nothing. Charged up the battery. noticed that i was not getting any sparks on the negative cable so I used the chassis to get the ground. battery charged right up and I was pulling 14 volts. Drove it a couple of days now problem. then let it sit for three days and again battery was dead. Had the same problem with the ground. Charged it a second time and again no problem so far. could the negative cable be causing some sort of drain? what could be killing the battery ?
Old 07-29-2013, 08:26 AM
astroracer's Avatar
Pull off the negative cable and clean both ends very well and re-connect. Rust and corrosion under 30 yr old connections is not letting the battery charge through the normal channels. If you can't charge the battery by hooking it up through the negative post, the alternator will have the same issue.
Also, how old is the battery? It may have a cell going bad which is why it won't hold a charge.
Mark
Old 07-29-2013, 08:47 AM
The connection are real clean. However i remember when the battery was installed about a year ago I was having issues with the side mount cable bolt not threading real good. Cheap ***** Advance auto battery. I did tighten it up a bit. I will see if that works.
Old 07-29-2013, 10:06 AM
With everything electrical switched OFF disconnect the battery ground cable and place a volt meter positive lead to the battery side of the cable or post depending on where you made the disconnect. Touch the ground side lead to the chassis where it will make good metal to metal contact. Observe any voltage reading on the meter. If a voltage is present, this tells you that some circuit is sneaking power. The offending circuit can be isolated by pulling the fuses one at a time and observing for the drop in leakage voltage at the meter. The alternator is another source of potential leakage, so you want to disconnect it from the system. Internal failures aside, the diodes tend to drip a little currect all the time so you want this thing disconnected except for testing its contribution (if any).
Batteries are also a source of internal leakage of individual plates to others or cells. About the only way to determine if there is enough internal leakage to cause a discharge is to have a battery tester that can put a heavy load on it while tracking its ability to sustain that load for a prescribed time period. Most decent battery shops have the specs by battery and the equipment to perform this.
Also, a simple at home test of alternator output is to switch everything electrical on with the engine running about 1500 RPMs. Then with a volt meter tapped off the battery's positive terminal test the systems output. The alternator/regulator should be able to hold 13.5 to 16 volts against the full operational system load. If it can't hold 13.5 there will not be enough excess voltage available to recharge the battery. If the output is higher than about 16 volts, with or without the full system electrical load, the battery will be overcharged. This heats up the plates and electrolyte which can result in plate warpage and steaming the electrolyte out of the battery.
Bogie
Old 07-29-2013, 10:39 AM
Bogie,
Sounds like you have done this before. i will try all of that tonight. Cheers!!
Dead Battery scrot Electrical 7 05-13-2010 06:38 AM
dead battery fasttruck Electrical 10 03-22-2007 07:39 PM
i need some help. battery keeps going dead. 406 ss monte Electrical 1 05-31-2005 01:56 AM
Dead Battery-HELP!? 5window Electrical 4 04-29-2005 08:56 PM
Is my battery dead? Rubberman2003 Engine 4 09-20-2003 06:26 PM
