Sudden loss of valve adjustment is usually a sign of camshaft failure. But, check that none of the rocker arm studs are being pulled out on the affected valves, and that no valve springs are broken
Compression test
Run a compression test and leak-down test. Make sure none of the rocker nuts are over tightened or it will hold the valve open. Turn the engine over a few times and make sure all the rockers move the same amount. Make sure all the plugs are sparking and at the right time. Let us know what you find.
ok, so I decided on my day off to tear it down some. didnt have time to go to indepth on it.
I went ahead and removed the intake manifold. Needless to say that the gasket was beyond tore up. But it went down hill from there. I didnt have a compression gauge to check the cylinders. But I had a buddy turn it over by hand. I did find that the #6 was not sealing at all. both valves were moving good. however when it go into the compression stroke I could see bubbles leaking from the intake valve and you can hear a hissing noise coming from it. I also noticed that the two valves had a different amount of travel when they closed. the intake valave didnt seem toclose enough like the exhaust valve did. Also when i removed the intake the exhaust port that connects the #4 and #3 exhaust valves was clogged. i had to chisel it out with a screwdriver. I cleaned everything up and also noticed that on passenger side head there were large gouges taken out in the head by the #2 and #4 Intake valves. I did check the plugs and the amount of spark and the color of them. They all spark the same and all but the #6 plug are a slight brown color. the #6 is still white. I am sure at this point I need to replace he heads. I am sure I could probably get away with just getting a valve job. but seeing the knicks in the head concerned me. I replaced all the intake gaskets. I also reset the timing. it was also off some. it runs better than it did but is still popping when it is under a load. if I am gentle with it she seems to do ok but the slightest hill I had to climb you can feel the loss in power and she starts popping. Is there anything I could possibly do with the valves to fix them without replacing the heads or am I at the point I am lucky it is still running? |
dead cylinder
Next post, please go to the bottom of the page an hit the SPELL CHECK I think you'll be surprised. thanks
need to do a compression check.
sounds like the cam is flat and the heads need work. a valve job on an old v8 is 125.00, can get a summit cam and lifters for 110.00, and a gaskets for 60.00. so 300 dollars should cover it (plus your labor). |
I know I need to do a compression check. I know it is easy and fast just a matter of getting the time off to get it done. I was expecting about that much for the parts. I guess i am going to have to force work into giving me the time off to get the compression checked. i know it was done years ago. i had the intake and rear main gaskets replaced. He said he ran the compression and all were up to 120 psi but the #8 cyl was running 90. Now it seems it has moved into other cylinders like a disease HAHA. imagine that!! Thanks for the info
Ok well at this point I wont lie. You just spoke spanish to me. LOL I uno dos tres and that is it. I got the basics and can take something apart and get it back together like it was new. IF I know what I am looking for and doing. As for what i have done to i. I have dealt with all that before. but i have never really messed with the rockers other than tightening the one up that was about to fall off.
Thanks overdriv. i am going to try that this weekend. doesnt look tough at all. Most of everything I have learned so far has been hands on. So again thanks. I am hoping that helps some. Only because I dont want to start learning how to install a new cam yet haha. I was hoping to do that when I find another engine. i have always wanted to build one from the ground up to put in my camaro. It is looking like I might be doing that sooner than later.
but i do have anotehr question. I have read a few places about the popping also being linked to a lean condition or retarded timing. i know the timing isnt retarded. But as for running lean. Well that I am unsure of. I know it has plenty of fuel flow. Is there a way to find out if it is running too lean? |
Ok so here is a question i was pondering today at work. I know I had been told a possible bad lobe on my cam could cause the issue I have with my car. however, when I had the intake off and watching the valves open and close. They all did just that. the intake fully opened and just don't seem to close. So that would rule out a bad cam right? second It was mentioned to adjust the valve and make sure they are zero backlash. I read up on it. looks simple. But the question I have at this point. If i never had a issue up until recently, wouldn't the rocker be loose when the valve is closed? Not holding it open. A nut doesn't tighten itself down on a spring loaded valve. I am going to buy a compression gauge tomorrow morning and test the compression. but I wanted to get someones opinion on it before I start messing with the valves. There is one I know for a fact came loose and that was on the #4 cylinder intake valve. i just tightened it down to stop the slapping it was doing. So that I will adjust properly. but can someone answer the other questions I have please.
