This may be a stupid question, but do all 4 of the throttle plates open/close simulataniously? Or do two of them open at certain times when going WOT?
all 4 open at the same time. but the secondarys have an air valve that is suposed to block some of the air upon WOT. its supposed to block some of the air to let the fuel catch up but it opens up just a split second after the plates open. i can adjust that to get more air faster but i tried adjustin it to let more air in and vise versa. but the dead spot is still there.
I had the same problem with the exact same carb and intake setup you have...Timing fixed it for me though...I have mine set at 12 degrees...Have you tried retarding the timing since you've done the other changes?
i changed my fuel filter (way dirtier then i thought) i looked at all my fule lines and the tank. everything looks good. the pump looks good but i didnt pull it to get a really good look. i dont know if the filter fixed my prob coz i tried pullin my oil pan out to replace the gasket coz it was leakin my couldnt get it out
so right now i dont know if changin the filter fixed it. after i figure out my oil pan ill see how she runs if its the same ill pull the fuel pump and look at that. far as i know its workin just fine but ill still pull it. any other ideas that might coz my dead spot???
| dead spot in acceleration | jrm123180 | Engine | 5 | 03-23-2006 09:37 PM |
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| part throttle flat spot | ss427 | Engine | 1 | 05-11-2005 12:31 PM |
| dead spot holley help | slammedchevy86 | Engine | 3 | 06-12-2003 06:06 AM |
| Proper throttle spring placement | willys36@aol.com | Engine | 1 | 11-13-2002 07:19 PM |
