dead at WOT - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2007, 07:08 PM
jrm123180's Avatar
A Learning Hobbist
dead at WOT
ok...heres the deal. On my 79 Chevy K10 with a 350ci and th350 trans and np203 tcase, when I put the peddle to the floor to WOT the engine seems to die for a sec and then comes alive again with out it seeming to kick down. Now recently I noticed it wasn't dieing, but it was not kicking down either. When I looked under the hood to check the oil I noticed that the kickdown cable is now disconnected (which I know it wasn't before when it would tend die).
Any one have a suggestion as to what this may be? Also, I have a shift kit in the tranny...
Thanks,
Steve
Old 02-02-2007, 07:10 PM
Wiki Edits: 31
at first it runs rich, and stumbles, then leans out. carb is likely out of tune/ in need of rebuild
Old 02-02-2007, 08:01 PM
jrm123180's Avatar
A Learning Hobbist
I had the carb rebuilt about a year ago professionally. maybe out just of tune?
Old 02-02-2007, 08:07 PM
Wiki Edits: 31
probably. somthing is giving it too much fuel when you first step on it.
700R4 - TV cable tension problem wont allow WOT AussieModder Transmission - Rearend 4 07-02-2006 02:47 AM
Sputtering at WOT - Help leejoy Engine 4 05-20-2006 05:32 AM
Stumped on 85 Caprice - not power @ WOT sabino56 Engine 11 02-12-2006 07:30 PM
RPM at WOT decreases..Starved for fuel?? tommytempest Engine 10 11-19-2005 08:54 AM
Popping at WOT....vaccume advance? jrm123180 Engine 3 02-24-2004 05:57 AM
