Scoty,
the acid destroyed the oxygen and moisture barrier provided by the paint to slow and prevent rust growth in the presense of a electrical charge (provided by the batt neg energy flow) for rust to "grow", all three (charge/moisture/O2) have to be present, you can't eliminate the electrical charge (just static electricity in the air is enough).... so all you can do is build back a moisture and O2 barrier with epoxy/seam sealer/spray undercoating/etc/etc to slow the rust growth inside the seams... every morning there is condensation moisture on the metal, do what you can to insure it drys absolutely as quickly as possible,,,especially any place it might collect.... (can't hurt/might help/costs nothing?) I have a windex bottle with about 2 tablespoons of baking soda disolved in (bottled) water, so I can force/flood the solution in every possible direction on the tight areas.... cut down a cheap plastic batt box to just a tray under the batt... be sure there is lots and lots of air flow over the batt, to disappate the acid "fumes" given off during a re-charge cycle.... bored? to much time on your hands? laundry detergent has a slight base PH, (and cuts grease pretty good) wash the whole engine compartment to neutralize any condensed "fumes".... LOL, bottem line: "mother nature" always wins (eventually)... steel is a unstable compound and mother nature wants it back in the original stable Fe form period!!!! |
Thanks, guys. It's good to hear opinions from both perspectives. No harm in trying to stop the damage from getting worse, I suppose. I'll have to go poke around and see how bad it really is and then go from there.
| Sulfuric Battery Acid Uses | Holder350 | Garage - Tools | 32 | 05-05-2008 09:20 AM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| battery acid | steve t | Electrical | 6 | 09-21-2006 07:40 AM |
| Need help please with an electrical headake | bowtieorbust | Electrical | 15 | 01-26-2006 03:01 PM |
| Best Rust Inhibitor? | bigbrowndog | Body - Exterior | 45 | 11-21-2004 08:26 PM |
