Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dealing with Napa on air compressor...???
Old 04-17-2005, 11:49 PM
Cliff Elikofer Cliff Elikofer is offline
Looking for opinions or your thoughts on air compressor's. Mine is down for the count and I'm looking to replace it. I'm looking at one from Napa (free shipping). I included the stat's incase the link doesn't load up. I tried it last night and it wouldn't load, site or server might have been down. Anyways, the one below is the one I'm thinking about getting. One thing Napa said, it takes a 60 amp double pole breaker to run. Which means I'll have to use #8 wire (by local code). Thats the only thing holding me back, cause thats allot of juice to run on (peak amps that is).
What have you got and are you happy with it? Have you dealt with Napa before? Like buy things of this nature before?
http://www.napaonline.com/cgi-bin/nc...&usrcommgrpid=
Attributes:
Attributes: Air Compressor
Gas or Electric: Electric
Stage Type: Dual Stage
Horsepower: 5 HP
SCFM Rating: 16
Maximum Pressure: 175 psi
Pump RPM: 800
Phase & Voltage: 1Phase, 230v
Motor Type: Baldor
# of Cylinders: 2
Pump Material: Cast Iron
Type: Reciprocating
Series: Professional
Magnetic Starter Included: No (Napa said it's included)
Magnetic Starter Required: Yes
Lubrication System Type: Splash
Tank Type: Horizontal
Tank Capacity: 80 gal
Height: 53''
Length: 71''
Width: 31''
Weight: 580 lbs
CFM Pump Displacement: 21.7
Name:	air compressor.jpg
