death wobble - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-14-2012, 07:37 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by T-bucket23
Are you sure you don't have a frozen caliper or a bad u-joint in an axle
Chet, This is a C-3500. Two wheel drive. No axle joints.
  #17 (permalink)
Old 05-14-2012, 08:34 AM
boatbob2
Wobble,,,,,,,,,
Could also be caster or camber.........MAY need more than specs call for........
  #18 (permalink)
Old 05-14-2012, 08:46 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Yup, I mentioned that in post #9 .
  #19 (permalink)
Old 05-14-2012, 04:38 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Have you check the drag-link bar and also does it have the adjustable ends on it as well ?
Cole
  #20 (permalink)
Old 05-14-2012, 08:22 PM
death wobble
what are the drag link bars i also checked the lower ball joints and they are not loose on both sides
  #21 (permalink)
Old 05-15-2012, 07:44 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
The drag link is the connection from the pitman arm on the steering gearbox to the tie rod.
  #22 (permalink)
Old 05-15-2012, 07:32 PM
death wobble
the only thing that i can adjust are the tie rods i am thinking about replacing the the rods the only thing i have a little play is in the gear box but i took it to a friend of mine and he told me that there is nothing wrong with the gear box i did find out that it does have the wrong size tires on the truck the tire size is suppose to be a 215 16 but the ones that are on it are 285 16 would that cause it
Ballancer wobble...? UR50SLO Engine 11 03-30-2007 08:14 PM
Death Wobble firebird450horse Suspension - Brakes - Steering 2 10-02-2006 06:53 PM
wheel wobble ls67 General Rodding Tech 7 08-19-2006 11:47 AM
Wheel wobble jamn50 Transmission - Rearend 2 04-05-2006 06:21 AM
Wobble in flywheel ok? bartamos Engine 3 07-25-2005 07:58 AM
