Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Death Wobble
Thread: Death Wobble
Old 10-02-2006, 05:41 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Was the solid axle in new condition or a junk yard part? Are the king pins, bushings, tie rod ends, etc. in good condition? If are all affirmative, then your alignment is out. Probably needs more caster which is achieved with thin aluminum wedges that insert between the spring and axle mounting pad to tilt the axle back a bit. Take it to a specialty truck suspension shop, not you local Costco.
