Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Death Wobble
Thread: Death Wobble
Old 10-02-2006, 07:53 PM
Triaged Triaged is offline
Once you do all the stuff recommended by Willys try this. Put two 1/8" thick fender washers under the top king pin cap. It will put more preload on the kingpin spring to compensate for the (guessing) larger then stock tires you are running. I am not exactly sure why it works...but I know many people that have tried it and it has worked for all of them. If I can ever get my truck back on the road I will do it myself.
