tom ton |
But stock cam bearing won't hold up for a season in these engine and there not much different in spring pressures compared to the street performance engines we build. We have seen what happens when the right cam bearings are not used and we don't take any risks at our shop with the engines we build and if a customer steps up to better heads with better springs and a bigger cam there should not be any problems with the better cam bearings. |
It's just too bad that we all don't build engines as good as you do. I guess the fact that I have been doing this for over 25 years and have had no cam bearing-related failures or problems doesn't mean a thing............ I know dang well when a better cam bearing is called for and it ain't a warmed over street engine. Which is probably below you, but it's what I make most of my money on. tom |
I never said nobody builds a better engine then me, I would REALLY LIKE TO SEE THIS POST as I am sure its not out there HMMMMMM your just another guy shooting the BS from that statement. As far as buiding performance engines we have been doing this for over 30 years and we are quite equiped for the machining of performance engines compared to some one who just builds warmed over street engines ( What ever those are LOL). Most of these guys here are building performance engines and not warmed over street engines and most guys including you don't even know there are performance cam bearings for the SBC If a guy is building a performance he should be using better parts then what is used in a stock warmed over engine. After 30 years of building performance engines we have seen what happens when the right cam bearings are not used and for an extra 7 dollars why take the risk of ending up with chewed up cam bearings. Nobody builds a better engine then me, Very interesting statement |
RIGHT, Carl, whatever you say. All one has to do is read between the lines in just about every post you make. Besides being borderline advertising for your business (if we edited out the subtle advertising in your posts, you wouldn't have much other to say), you always seem to make a point about hou YOU do it at YOUR business and how YOUR way is so much better that the other guy. No, you don't come out and say it, but is sure is implied. And I'm not the only guy here who thinks so. I'm sure you don't know what a warmed over street engine is. You seem to think everything needs the full-on, high-dollar machine work that you do on all the high-performance engines your shop does for all your high-performance customers (BTW, why do the guys I know out east not have a clue as to who you are?). Keep on with your advertising, er, orations, Carl, we are all SO interested. Funny thing, if you would cut back on the subtle advertising and self-promotion, most of your posts would have some merit........ tom |
tom |
I don't avertise here but I do give my knowledge on what works the best and what we have seen over the years Maybe my engines make so much power we have to use the good cam bearings. LOL I got an email about your border line advertising is there a differance between you and I or are you above me!!! What we do for work is not high dollar as you may think but we do more to an engine then someone that justs builds a warmed over street engine I am sure and I work is much more accurate then some who just build a warmed over street engine. I bet there are more guys on the east coast or more then then that the whole contry and Canada that know who I am over you as I am sure of that, Go over to the http://speedtalk.com/forum/index.php...89d986a2c13b80 and ask these guys who I am as most them I have met through bus. transactions and have met some of them at the Pri-shows over the years. How many guys over there have you work with????????????????????????????? |
I'll clear these matters up right now.
Nobody, but nobody builds better engines than me. For it is written, Yea, even so, it was given to Nairb, the knowledge from birth, and yea let this be a sign that whosever disagree shall die the death of many small dogs as they are eaten by bigger dogs. Thy cam and thy shaft, they comfort thee and I shall dwell upon the holy dyno forever and ever, amen. As it is written, So shall it be done. I hope that clears things up as to who the authority is around here. |
And my screen name does not contain my business name. Like yours. As far as who knows about my shop, we are well known in our region. You haven't heard about me because I haven't posted the name of my shop on this site. In spite of being a small shop that does not advertise out of our immediate area, we do a lot of business. I do work on all types of engines from everyday drivers to 8-second, 1/4 mile drag cars to class-winning circle-track cars.And we do it without name-dropping or references from other web sites. Carl, I do not doubt or argue that you have great knowledge about building race or high-performance engines. I have actually learned a lot from reading your posts here and on Speedtalk. BUT that doesn't mean that I have to agree with you on what type or manufacturer of a given part is best. You make it seem that your opinion on a given issue or part is the only valid one. But that is only an opinion based on your experience. A lot of guys build engines that don't need the extent of work that the type of engines you build require. Sure, having the best of parts machined with the most exacting and capable machines would be nice, but it isn't practical or needed in many or even most of the builds that the guys talk about here at HR.com. I think that if you showed a little more respect for those that are just as successful in engine building as you are but have different points of view or experiences we wouldn't be having this exchange. For the dollars my customers spend on their engines, they are just as happy as your customers are with you. And if my customers had problems with my work, I certainly would not have been in business as long as I have at the same shop and owner with the repeat customers and increasing business that I have. All without advertising on the web, in any shape or form, here or anywhere else. tom Last edited by machine shop tom; 03-15-2008 at 08:03 PM. Reason: nitpicky little grammar things |
sam-missle |
The name Machine ShopTom that has nothing to do with your bus.????? We would not take the chance of using cheaper parts and take a chance on a bearing wear issue and for the extra 7 dollars I am sure most guys would spring for the better bearings on a performance application. Now on street engine that have 420 lift cams and stock springs stock bearing would work fine, Hell even the GM engines come with aluminum cam bearings which are a lot tougher then any babbit bearing. The engines you build you can probably get away with stock bearings but with what we build and what we have seen what works and what doesn't we always go with the better stuff. (For 7 extra dollars) We work with a lot of engine builders and engine shops all over the country and Canada and have helped them with their engine developement and 99% of the time what we help them with really seems to work over what they have been doing. A lot of my friends and partners over the years work in the Cup Shops where I have a lot of ties to and talk to them about the latest technology out there and from time to time I get to visit those shops down south. And I like a good debate once and a while
Carl, your screen name was changed once already because it was a link to your business. As it is now, it still is your business name.
Machine shop tom describes my job. Nobody here even has a clue as to what the name of my shop is. BIG difference. BTW, when I build a race engine, I use race cam bearings. When I build a heavy-duty or stout street engine, I use performance cam bearings. When I build a mile street engine, I use stock-replacement cam bearings. I may not use the brand you do, but that doesn't mean I am short-changing my customers. "...Over the years we have seen to many engines built with substandard parts and when we get them apart the customers not happy with what was supplied for parts by there shop that did the work. ......." I could have not described my business any better. We probably have far more in common than not. tom Last edited by machine shop tom; 03-15-2008 at 04:55 PM. |
Maybe I should change my name to Machine shop Carl LOL |
