Deburring the burrs off quadrajet? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2012, 01:13 AM
Skylark
Last journal entry: 70 SF 455 project
I'm cnc operator for over four years that has strong habits to deburring everything I see. I'm seeing several burrs and chipped every where on my dummy quadrajet that I'm practicing with. I can't help but wondering why factory didn't deburr them? Are there reasons why burrs there? To distrbute the air/gas or it cost money to Burr them? I have all access to deburr tools, pin gages and precious drill bits. I'm thinking about deburring them without change measures. I even thought about Polishing internal. Bad move?
By the way, I do want join the club where they have lot of wild ideas for quadrajets like snake oils, screen gaskets, etc... Lmao
Old 05-25-2012, 01:29 AM
blwn31's Avatar
It comes down to cost.
Keith
Old 05-25-2012, 02:53 AM
Skylark
Will deburring Burrs effect anything?
Old 05-25-2012, 08:22 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
I assume you are talking about deburring the throats or barrels of the carb? Deburring won't hurt, but I doubt you are going to see any improvement. You have a lot more bottlenecks in an engine than a 750CFM carb.
Old 05-25-2012, 08:37 AM
Banned
Deburring it can help not only airflow but fuel delivery. If you do a thurough job you will need to alter the fuel metering to compensate, you'll likely have to lean it out as a smoother airflow should produce a stronger signal. If you do a super thurough job complete with filling in voids and thinning the shafts you could come close to a 100cfm gain with no significant increase in throttle size, in otherwords it'll work better at idle through redline.
A thurough job will take some time though, like 10-15 hours.
Old 05-25-2012, 01:26 PM
Skylark
Everywhere..... Throat of barrels, edges, booster rings, sides of internal and external, floor of bowls, edges.
Old 05-25-2012, 01:30 PM
Skylark
I'm practicing to rebuilding quadrajet for my 70 stock Buick 350. I don't think gain 100 cfm would be good for this engine. I just worry about deburr will effect poor performance.
Old 05-25-2012, 01:59 PM
Banned
More cfm will not hurt ANYTHING it will make some things a lot better. Your signal will be a lot stronger which will allow you to have a more consistent tune.
Unlike swapping to a carb with a larger throttle bore (higher cfm rating) gaining cfm on the same size throttle bore will not have a negative impact at low speed.
A holley hp carb uses the same venturi and throttle dimensions as the standard line of carbs but they flow more and have stronger signal due to them being smoothed out a little.
As long as you retune your carb after working on it it will do everything better.
Btw if you think a quadrajet is bad my edelbrock 1406 has a very disrupted flow path, I've considered smoothing it but since its just a carb I slap on engines to break them in its not worth it.
Old 05-25-2012, 02:20 PM
Skylark
Is there step by step to do this? So, I can review to see if it's worth it.
Old 05-25-2012, 02:36 PM
Banned
There's a very good write up on a holley being done, I can't remeber the site right now though, google it.
Old 05-25-2012, 02:49 PM
Skylark
Ok what's title do I use to Google it?
Old 05-25-2012, 07:08 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
biggest problem with Q jets and poor performance is the throttle shafts wearing out the baseplate holes,, causing major vacuum leaks and poor tuning.
Old 05-25-2012, 07:17 PM
Skylark
Yea I'm planning to order bronze bushing throttle kits for primary and secondary throttle when I'm ready to do real rebuild on original quadrajet.
Old 05-25-2012, 08:07 PM
Skylark
Oh yea, I just remember that I might going convert my th350 to m21. My question is if I do that, do I have to make some changes on quadrajet for m21? Or will it be fine?
Old 05-25-2012, 09:34 PM
Don't you mean richen, since more airflow would need more gas?
Converting from external choke quadrajet to electrical choke quadrajet silentpoet Hotrodding Basics 4 10-03-2011 01:38 PM
Anti-Sieze on cutting burrs oldschool hero Garage - Tools 2 08-31-2011 09:52 AM
Deburring pistons barnym17 Engine 2 11-29-2007 07:39 AM
carbide burrs volkswagentuned Garage - Tools 12 10-14-2005 02:11 PM
Quadrajet novatech Engine 16 04-24-2003 11:44 AM
