Decel Smoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2010, 05:38 PM
Decel Smoke
Engine is fresh rebuilt 406 SBC with new rings and heads. When accelarating hard, I am getting a small cloud of blue smoke between shifts. (manual)
From my research I understand that this can occur from oil entering the carb from the PCV line during a shift. I have checked this line after a hard run and I do find a bit of oil in the line.
I am wondering what the best method is to prevent this puff of smoke?
Valve covers and aftermarket PCV are new and seem to be working fine. There is a small diffuser inside the valve cover, under the PCV hole, as well.
Would installing a catch can between carb and PCV help, or any other suggestions?
Old 09-18-2010, 07:00 PM
LATECH's Avatar
I would look at the baffle for the pcv valve. sounds like it needs a modification to work well. It could be oil getting in over the top getting to the valve . i would try to do something that would not interfere with the appearance under the hood.
Could also be you need a pcv valve with a heavier pellet in it.
Old 09-19-2010, 10:21 AM
Try removing the pcv from the valve cover and driving.What intake and gaskets are on it,sometimes the bottom of the intake don't seal and they pull oil from the valley.
Blue smoke ...?? Malibu1347AD Engine 5 12-16-2009 10:54 AM
Ping, blue smoke, - repeat daveEM Engine 1 07-03-2006 01:22 PM
Bewildered at the white smoke? HotRodMan Engine 5 09-08-2004 09:32 PM
Oil smoke or....? 383 Chevy Finmike Engine 8 07-08-2004 05:25 PM
Massive Smoke Tina Engine 11 08-17-2003 07:59 PM
