decent spray gun - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 09:47 PM
decent spray gun
i let someone barrow my old gun and it came back in 2 pcs. is it possible to get a decent gun for around 200.00? what do you recommend hvlp or regular? i had an old sharpe 75 and figured its time for a change anyway.the compressor i have is a 5 hp 25 gal craftsman. any help would be appreciated.
Old 02-09-2006, 11:10 PM
decent spray gun
It generally depends on what you use it for. Most of the Sharpes I run across are too hard to clean, due to the double fluid inlet. Astro makes a gravity feed that breaks down clearcoats as well as any for about $90. Get the smallest tip (1.2-1.4); this is also good for basecoat. For primers, a larger tip will save your shoulders on full-panel primes, go with about a 1.6-2.0 for these. That's whith a 2 part catylized primer. For spot priming, just cut the mix down a little with some urethane reducer. For higher-end painting, a DeVilbiss GTI plus is a great gun for the price. It puts out an absolute fog of a pattern, at the expense of more material waste.
Old 02-10-2006, 05:41 AM
302 Z28's Avatar
There is a host of decent knock off HVLP guns on Ebay that do a superb job. One of the most popular is an Iwata W-400 clone. I have aslo purchased several HVLP guns from Harbor Freight that also do an excellent job.
http://www.harborfreight.com/cpi/cta...emnumber=43430
Vince
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
one giant orange peel flamedfordbronco Body - Exterior 14 06-20-2007 09:04 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Decent Remote Spray Gun? starquest Body - Exterior 2 04-26-2005 05:13 AM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
