decided to clearcoat it - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2009, 08:03 PM
I painted my car with ppg omni with hardener.It has a little orange peel and runs.I have decided to clearcoat it.How many coats would I need and how long or what do I do between coats.They both are acrylic enamel with hardener.What I mean is do I sand clearcoat between coats or what? thanks proge
Old 03-06-2009, 06:12 AM
I always thought Omni was only in Urethane, like in the basecoat/clearcoat system.
I don't know much about Acrylic Enamel clear, just wanted to pipe in with this:
The SPI-brand High-Solids clear that I bought says on the tech sheets it can be used over Catalyzed Acrylic Enamel. If you did that you'd have a really good-looking durable finish as it is Polyurethane. It's also one of the best clearcoats out there.
If you sand that Enamel flat (open it up) I'd wait a couple of days to let it offgas before re-coating it even though it was cured with a catalyst.
Old 03-06-2009, 06:26 AM
302 Z28's Avatar
That is excellent advice and will prevent "solvent pop".
Vince
I wetsanded through my clearcoat!! (and I have lots of tree sap!) fiscus Body - Exterior 4 06-18-2010 11:13 PM
Clearcoat Scratch cgates Body - Exterior 2 05-02-2007 07:02 AM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
Shot clearcoat and roof paint broncoII88 Body - Exterior 2 04-25-2005 04:22 PM
Using Polyurethane for Clearcoat??? teched Body - Exterior 4 10-18-2004 06:00 PM
