Deciding between gears or a transmission. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2011, 08:59 PM
I have a pretty stout 350 in a short bed single cab s10 truck. At the moment I am running 26 inch tall tires, 3.73 rear end behind a turbo 350. I have a 700r4 and a 3.08 rear end sitting in my yard. My highway speed RPM is around 3500 RPM. With my 350 I have a 3000 stall and the 700 has a stock converter. my cam is a voodoo 262. I like my bottom end, but I could use some gas milage and a little more top speed. 700r4 or 3.08?
Old 06-04-2011, 09:08 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
the rear end swap would be less work, if the taller gears will work with that stall
but i think the best would be to go with the trans swap and buy a converter for it, and keep the lower gears in the rear
Old 06-05-2011, 06:12 AM
GMCBEAST's Avatar
I definately agree, trans won't interfere with the motor set up you have, those 3.08's may be sluggish on the low end. Trans will cost a little more unfortunately (converter and driveshaft.)
fresh rebuilt turbo 350 transmission hardly shifts into reverse and no forward gears 79malibuclassic Transmission - Rearend 3 04-10-2011 11:00 PM
Th350 transmission has no forward gears? teach4nc Transmission - Rearend 4 03-21-2009 07:56 AM
gears, transmission, and rpms... SeeMy355 Transmission - Rearend 6 02-27-2009 02:17 AM
help deciding on SBC F3RR3T Engine 9 10-01-2008 02:38 PM
Best Transmission And Gears 1967camaro327 Transmission - Rearend 3 05-25-2005 11:53 PM
