deciding on mini spool gm 8.5 78 z28
any experience w/ installing issuesd?
Sorry to say, But if your going to be useing this on the street..You won't be hearing want you want to hear..:D
Auburn Gear 542018 Auburn Gear Differentials |
Can only be installed in an open diff carrier.
Some brands require the c-clips to be modified on the bench grinder. Not recommended for street use. |
why do you want a spool?maybe we can offer better ideas?Is traction an issue? are you drag racing? are you making horrendous power?
Mini spools are for street stock dirt cars. They have essentually stock 2bbl engines and
are not on pavment. What yhou are trying to do will not work. You are just going to bust axles. This is not for the street. Get a Auburn posi or a Eaton posi. Do nt use any of the factory GM stuff or a spool. Save your money and get the Auburn or Eaton posi. It will pay off in the end. |
| All times are GMT -6. The time now is 08:02 AM. |
