deciding on mini spool gm 8.5 78 z28 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 02:18 PM
any experience w/ installing issuesd?
Old 11-12-2012, 02:37 PM
life is a temporary assignment
Sorry to say, But if your going to be useing this on the street..You won't be hearing want you want to hear..
Old 11-12-2012, 02:49 PM
techinspector1's Avatar
Wiki Edits: 326
Bad ju-ju for a street driver, Bwana. Use an Auburn posi or other brand.....
Auburn Gear 542018 Auburn Gear Differentials
Old 11-12-2012, 03:11 PM
Can only be installed in an open diff carrier.
Some brands require the c-clips to be modified on the bench grinder.
Not recommended for street use.
Old 11-13-2012, 04:11 PM
vinniekq2's Avatar
why do you want a spool?maybe we can offer better ideas?Is traction an issue? are you drag racing? are you making horrendous power?
spool vs. mini spool 72fordlb Transmission - Rearend 7 11-14-2009 02:44 PM
Full Spool or Mini Spool??? S10 Racer Transmission - Rearend 1 04-02-2008 06:50 AM
difference/pros/cons of spool and mini spool? "70" Cougar Transmission - Rearend 20 03-03-2006 10:42 AM
What's a spool and mini spool? 84Z Transmission - Rearend 2 01-31-2005 07:33 PM
mini spool camino_man Transmission - Rearend 3 02-08-2004 06:34 PM
