Deciphering TRW pistons? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2003, 10:16 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hey All.
Anyone now a website to figure out TRW piston codes? The #'s are L3022F-30 Thanks, HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 09-13-2003, 10:46 PM
Jmark's Avatar
Well, its a stock replacement piston for a 67-70, 250-300 hp chevy 350. Comp ratio is not stated.
Your piston is a forged aluminum, .030 over stock diameter.
The following numbers are stock equivalent (sp?) for the above engine.
2244P SEALED POWER, L2256F TRW, L3022F TRW , P557 BADGER
350 VENOLIA, 345NP FEDERAL MOGUL, 350 LUNATI, JE 139904, 99579 ROSS, C6-CP CP
got the info here.
http://www.ihra.com/tech/pistons.html
Old 09-14-2003, 11:09 AM
GearHead69's Avatar
'70 Chevelle '70 C10
TRW pistons
Part Numbers Starting with "H" are Hypereutectic pistons
Part Numbers Starting with "L" are for Forged
I tryed to find your part # and didn't have any luck..
I was looking here:http://www.flatlanderracing.com/trwpistons.html Good luck
Old 06-11-2010, 05:13 PM
Piston Code Dicephering
9.18 Malibu
I Have A 1986 Trw Catolog. It States The Pistons Are For 67 -70
350 Cid. H.p. Ratings Are 250,255,295,300.
These Are Cast Not Forged, All Forged Pistons Start With L2000f, And Cast Start With L3ooof. No Data On Comp. Ratio.
I Would Say From The Year And H.p. Ratings Probably 10:1 With 64cc Heads. Hope That Helps,
Old 12-05-2010, 08:31 PM
Can you tell me about this part # L2481 030
Thanks
David
Originally Posted by 9.18 MALIBU
9.18 Malibu
Old 12-06-2010, 08:04 AM
OLNOLAN's Avatar
L2481f-30
Buick 231 v6 turbo pistons. 234 ci w/.030, 7.96cr w/48cc heads. Hope this helps. I have more info if needed.olnolan
