Decking a Block... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2006, 10:29 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Decking a Block...
The main studs for my 400 SBC arrived today and I'm going to be taking the block to the machine shop some time in the next couple of weeks to have the block inspected and, if satisfactory, have the block bored as necessary and .020 removed from the deck surface to bring the deck to 9.005". My question is this, when material is removed from the block will I need to have the intake manifold machined to compensate for the shorter deck height? If so, how do I determine how much will need to be removed?
Old 12-29-2006, 03:24 AM
KernCountyKid's Avatar
If it aint broke, break it!
Last journal entry: Cab Corner - 2
I know I've seen a formula for this, but I think that the difference in deck height (.020) would have to be removed from both sides of the manifold (.020 on each gasket surface). Don't forget to factor in head resurfacing also, not just block decking.
Old 12-29-2006, 08:47 AM
don't mill the intake till you have done a dry fit measurement after decking...
mount and torque the intake with gaskets and no end seals.....
measure the ends gaps with a feeler guage, if you still have about a .030" gap your "OK"....but
small chance you will need to enlarge the heads ports top and/or bottem
the only "real world" way I know to check for port top and bottem alignment is to use a open plenum intake and a coat hanger to "feel" for an edge
never have done a 400 but for alot of motors....decking .020" is the practical max before alignments become a major issue....deck it less and sleep better
most blocks will clean up to true flat at .007 to .010 decking....
the extra compression gained by decking .020" will gain you next to no more HP (one full comp point=4% power gain)
if you do deck it .020" you will probably need different pushrods
the Ford formula for how much to remove from the intake:
.020" off the heads =.010 off each side and .014 off the bottem
(for a stock intake and heads)
Old 12-29-2006, 09:00 AM
I had my 400 block zero decked and run stock dimensions on the heads and intake. I don't think removing .020" is going to cause you any misalignment headaches.
Old 12-29-2006, 10:33 AM
johnsongrass1's Avatar
Race it, Don't rice it!
You guy's are over thinking this. You won't have problems
Old 12-29-2006, 10:38 AM
Blazin72's Avatar
Wiki Edits: 19
Thank you for the responses. The reason for decking the block is to bring the quench to .045". The particular head gaskets I've found are .040" and the particular piston I plan to use will have a height of 9.000".
Old 12-29-2006, 03:24 PM
King of my Man-cave.
Unless you mill the heads .020" or more, you shouldn't have any problems.
tom
Old 12-29-2006, 10:18 PM
You should be fine as we deck blocks 8.990 and with the the thinner performance intake gaskets out there we have had no issues so far.
Engine ID crash Engine 10 10-01-2006 07:43 PM
Small Block ID Help bluesman123 Engine 4 05-23-2006 10:07 PM
Decoding Ford Small block hotrodgs Engine 16 05-14-2006 06:15 AM
i'm looking for a better 400 s chevy block 406 ss monte Engine 3 08-23-2005 08:48 PM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 05:01 PM
