Decking a block - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2012, 06:54 PM
Decking a block
I talked to a guy that says when decking his block, he shaved off the ID # on the block. Is that even possible ?
The engine is from a 1969 Chevelle L89.
Old 03-26-2012, 07:06 PM
DoubleVision's Avatar
On a SBC and BBC it is, as the suffix code which tells you what the engine is and what it came in as well as the years is stamped on the front of the blocks deck. When the block is decked the metal is removed and so the suffix code as well as the other information stamped on the deck such as the VIN of the vehicle as well as what plant the block was cast at and the date will all be gone.
zero decking block 1975yellowC3 Engine 53 10-02-2010 07:27 PM
Decking a Block... Blazin72 Engine 7 12-29-2006 09:18 PM
Block decking DoubleVision Engine 4 10-11-2005 05:12 AM
Block Decking sb72elcamino350 Engine 3 02-26-2004 12:59 AM
decking your block 70 nova Engine 5 03-06-2003 03:04 PM
