Decoding Ford 300 6 tag on timing cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2003, 04:57 PM
Post Decoding Ford 300 6 tag on timing cover
I have a Ford 300 6 cyl. from junk pile.
To order parts it would help if I knew a little more about engine. On the front timing cover is a stick on bar code tag with the following.
Big letters left side O6
On the right side all the following
2K265AA
5 6 86
+10
Any help would be appreciated. Thank you.
Old 02-05-2003, 05:05 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Post
Their should be a casting number on the passenger side of the block with a letter C, D, E or F then a number 1-9 then a T then the letter E and then another set of numbers. If you can get them I can tell you exactly what year it is.
Old 02-06-2003, 10:42 AM
Post
[quote]Originally posted by onebadmerc:
<strong>Their should be a casting number on the passenger side of the block with a letter C, D, E or F then a number 1-9 then a T then the letter E and then another set of numbers. If you can get them I can tell you exactly what year it is.</strong><hr></blockquote>
The # is E5TE 6015-MB on the RS of block
Also on RS of block but up higher 6D18
After looking at # on timing cover itis a ZK265AA , not 2K265AA.
Thaknk you for your effort.
Old 02-06-2003, 11:36 AM
aka Duke of URL
Arrow
[quote]E5TE 6015-MB 6D18<hr></blockquote>
It is a 300ci (4.9L) from a 1985/1986 light truck. Cast on 18 APR 86.
