decoding ford 302 block - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2008, 10:28 PM
Can you please help I have late model ford block and cannot find any info on how to decode it. The older ford blocks had a number behind where the starter mounted but the new blocks (roller cams) have some id marks below where the back of the heads are. Can anyone help or know of a web site? thank you
Old 07-12-2008, 12:14 AM
JeffB's Avatar
www.sbftech.com
Old 07-12-2008, 07:38 AM
woodz428's Avatar
Troll Hunter
The small blocks #'s were above the starter, not behind it. I'm not sure how late a block it is, but they were there as late as the mid to late 80s. I think that the FRPP blocks have them there as well.
Old 07-12-2008, 04:34 PM
onebadmerc's Avatar
I need a bucket of arc sparks
I have had a couple of Ford replacement service blocks that had no casting numbers. The only thing they had on them were a small metal stamped tag with the id numbers on them. One of the engines was a 360 and the other one was a 1980 Ford 302. I guess if you have one of these blocks and the metal tag is gone then you will need to do some measuring to find out what cid it is. Then check for one piece rear seal and see if it is a roller block.
Old 07-12-2008, 09:07 PM
You said 302.
One piece seal blocks are termed 5.0, since they have the new lightweight crankshaft balanced at 50 oz/in at the rear and 35 oz/in at the front.
One piece seal blocks can be flat tappet or roller tappet.
(Two piece seal cranks are 28/28 balance and heavier.)
To the best of my knowledge all assembly line 5.0 roller blocks are identical.
Big Block Ford ~ 429 ~1971 Help With Identification Please Rob Keller Engine 9 12-11-2007 03:42 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Decoding Ford Small block hotrodgs Engine 16 05-14-2006 05:15 AM
Heads for Ford 302 Coleman396 Engine 12 03-31-2004 08:51 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 09:20 AM
