I have had a couple of Ford replacement service blocks that had no casting numbers. The only thing they had on them were a small metal stamped tag with the id numbers on them. One of the engines was a 360 and the other one was a 1980 Ford 302. I guess if you have one of these blocks and the metal tag is gone then you will need to do some measuring to find out what cid it is. Then check for one piece rear seal and see if it is a roller block.
