decoding a t-10
i need some help decoding my t-10 out of my 70 amx.
#'s on housing reads T-10PJ8 K30.69 (nov.30, 69) 91 on the shaft the #'s are AS1-T10V02V or Y 316Y or 319Y T10P7A WG DIVISON Q2 H25-69 (AUGUST 25 1969) ALSO SHAFT HAS 6 NOTCHES ON IT. |
Your shaft numbers don't make any sense to me.
Here is a list of known shafts for T10s through 1980. ********** AMC: T10P-2B T10P-2C T10S-2D T10P-16B T10P-16C T10T-16 T10V-16 T10V-16B ********** Chrysler: T10F-2 T10F-16 T10G-16 ********** Ford: T10B-2 T10H-2 T10H-2A T10H-2B T10K-2A T10Q-2 T10B-16 T10B-16A T10H-16 T10J-16 T10Q-16 ********** GM: T10-2 T10A-2 T10A-2A T10A-2B T10A-2C T10D-2 T10E-2 T10K-2 T10W-2 T10W-16C T10W-16G ********** Unknown Application: T10S-2C T10U-16 ********** Studebaker also used the T10 but I don't have a list of shafts for them. Most likely your shaft is in the above list somewhere. If you can determine which one it is I might be able to narrow down your possibilities somewhat. |
t-10
i will juck up the car again and double check the #'s on the shaft.
T-10
#'s on housing are T10P-7 OR 1 B
SHAFT-T10P7A W G DIVISON Q-2 TAG READS - 3197057 AS4-T10V SHAFT HAS 6 NOTCHES ON IT. I NOW THIS BECAUSE WE TOOK OUT ENGINE AND TRANNEY 2 YEARS AGO, AND COUND'NT FIGURE OUT WHY IT HAD 6 NOTCHES. SOMEONE TOLD US DIFFERENT GEAR RATIO. I FORGOT WERE I PUT THAT INFO? Last edited by 1970amx; 04-28-2010 at 11:26 AM. Reason: wrong info |
Don't know if these will help, but here are a few AMC T10 links:
http://www.amccf.com/tech/amc_manual_trannies.html#T-10 http://www.planethoustonamx.com/main...nie_and_re.htm http://www.dragtimes.com/parts/1968-...482884764.html Last edited by mmerlinn; 04-28-2010 at 11:52 AM. |
| Brake lights switch | oldsmo | Electrical | 4 | 10-19-2006 11:23 AM |
| unusual 10 bolt GM diffy off '75 SW... | paulo 1 | Transmission - Rearend | 2 | 08-16-2006 08:10 PM |
| Engine Vacuum is showing 10 and no higher? | ataririder | Engine | 42 | 02-18-2003 07:12 PM |
| 10 0/0 theory | dinger | Hotrodders' Lounge | 3 | 09-12-2002 08:14 AM |
| 40 ply/s 10 clip | gcorbit | Suspension - Brakes - Steering | 0 | 01-28-2002 03:53 PM |
