Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - deep oil groove
Thread: deep oil groove
Old 03-13-2005, 04:16 PM
NorthStar's Avatar
NorthStar NorthStar is offline
This isnt a boneyard core that youre going to try installing into a "some vehicle" right? Theres other differences between engines too like bolt holes in ends of cyl heads, cam bearings, intake ports, balance shaft, cranks and rod weights. So you would really be sticking your neck out trying to do that.
Just to be sure what is your block casting number?
Oil ring groove depth
.155 = shallow
.190 = deep
When ordering parts you have to know the vin code, year model, and engine plant it was built in.
Look at the stamped number on right bank should be a letter R or T on there.
We can figure out the year from casting number.
