deep sump moroso pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2006, 10:21 PM
i plan on running a moroso deep sump pan about 9.5 inches deep, should i run an melling hi-volume pump because of the extended pick-up or a standard volume pump. thanks!!
Old 10-09-2006, 10:57 PM
The pickups for a HV pump and a standard pump will be different. You need to run the pump and pickup as a pair.
Old 10-09-2006, 11:15 PM
327NUT's Avatar
First question...do you have the ground clearence for a 9.5" pan? If you do then the standard Melling M-55 pump will work just fine. Just make sure you get the right pick up for the that pump and pan depth.
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 04:46 PM
Early Nova V-8 Oil Pan Front or Rear Sump ? yekoms Engine 3 11-25-2005 08:04 AM
Oil pan - kicked out sump good? dh79 Engine 4 06-15-2005 02:32 PM
C-4 Deep Pan nova69 Transmission - Rearend 1 05-30-2005 09:28 PM
Deep Oil Pan Dipstick????? juveteach Engine 3 06-10-2003 08:00 AM
