Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Deeper 700 r4 corvette filter ?
Old 03-18-2013, 09:29 AM
dwwl dwwl is offline
I bet that is why we couldn't find it, it was the 4l60e which is the 700 renamed. I'll check on that. I'll take my old 200 filter with me and make sure the filter tubes are the same so i can compare them side to side. I've had the 200 r4 pan deepened a extra 1 inch to hold two more quarts of fluid and i want that pickup to be lower in the pan. I'm also running cooler tubes in the bottom of the pan to help with extra cooling. We use to do that with the 400 trannys back in the day when WE drag raced. It realy helped alot. Thanks for your help Sir.
