Deeper 700 r4 corvette filter ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2013, 07:21 PM
I have been told that the corvette had a deep filter for the 700 r4 tranny. Can't find it. Parts store can't seem to find it. Maybe there was no such animal. Apparently the corvette had a deeper pan for a couple of years??????? I putting a 200 r4 together with a deep pan and need to put in a deeper filter. Any good Ieas???
Old 03-18-2013, 07:24 AM
rick 427's Avatar
Last journal entry: The Cheetah
Corvette 4L60E 97up had a bit deeper filter than the others of those years.
Old 03-18-2013, 08:29 AM
I bet that is why we couldn't find it, it was the 4l60e which is the 700 renamed. I'll check on that. I'll take my old 200 filter with me and make sure the filter tubes are the same so i can compare them side to side. I've had the 200 r4 pan deepened a extra 1 inch to hold two more quarts of fluid and i want that pickup to be lower in the pan. I'm also running cooler tubes in the bottom of the pan to help with extra cooling. We use to do that with the 400 trannys back in the day when WE drag raced. It realy helped alot. Thanks for your help Sir.
99 corvette fuel filter pressure xpsyclonex2002 Hotrodding Basics 7 01-09-2013 09:14 AM
Can a shorter filter be used on the 4L60e deeper pan ? old yukon Transmission - Rearend 14 09-03-2012 08:33 PM
Head Gasket or deeper? speede5 Hotrodding Basics 13 04-02-2012 12:25 PM
about to finally go deeper, help? stroker444 Engine 13 05-14-2010 07:56 PM
1984 Corvette 700 Trans Wont Shift Up billybonesmusic Transmission - Rearend 3 06-06-2006 07:23 PM
