Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Defining the term Big and Littles???
Old 05-02-2008, 09:37 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by RPM
Stared at one end and mig tack welded as I went till it just came together.
Did you do anything on the inside edge of the 14 gauge (the lip that runs around the core)? It looks from the picture like it has a nice rounded edge to it. Also, did you have to add any "fill" to the outside edge (the joint between the 14 gauge and the 20 gauge) so you could grind a nice transition corner there?
Always learning...and sharing what I've learned.
