defrost ducts on '37 ford coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2012, 10:53 PM
When I washed the coupe for the first time it leaked into the dash. I found the windshield drains were clogged and cleared them, but also wonder if it will leak into the defrost ducts even when the windshield is closed tight. Just trying to track where the leak is coming from.
Old 08-30-2012, 05:22 PM
Stu D Baker's Avatar
If you still have the original cowl vent, it most likely is leaking there. Stu
Old 08-31-2012, 12:05 AM
defrost duct on '37 ford
I no longer have the cowl vent, but I found the source of the leak. It is a tiny hole in the firewall under the battery and that has allowed water to seep onto the carpet. Easy to miss but an easy fix.
Airconditioning ducts harold45 General Rodding Tech 6 12-26-2010 04:13 PM
A/C,Heat /Defrost Unit For 33 Ford Vicky Fiberfab or Streetbeast Body abelski Garage - Tools 5 10-13-2010 04:43 PM
custom defrost lines... Sagacious Electrical 1 04-06-2007 11:37 PM
Oval defrost vent... chadsbodyshop49119 Interior 8 11-14-2005 12:01 AM
Heater Ducts MI2600 Interior 4 03-14-2005 06:59 AM
